Sony Bravia kdxg8305bu
SOLVED
Ukchatannie
Explorer
Purchased new TV this week and have a question - as the TV has no power button how will I turn the TV on if the Bluetooth remote control stops working.
1 ACCEPTED SOLUTION
Accepted Solutions
IamNic
Hello @Ukchatannie,
but it has. Check the back of the TV.
Location of the On-/Off-Button on the back of the TV - right side if you look at the TV from the front - left if you are looking at the TV from behind.Location of the On-/Off-Button on the back of the TV - right side if you look at the TV from the front - left if you are looking at the TV from behind.
  1. Via the button on the back of the TV
  2. By replacing the battery of the remote and switching it on with the remote then
  3. By purchasing a new remote to replace the broken one
4 REPLIES 4
IamNic
Hello @Ukchatannie,
royabrown2
Hero
@Ukchatannie
Tain’t the things you don’t know that catch you out - it’s the things you do know that ain’t so...
Ukchatannie
Explorer
Thanks found it.
Ukchatannie
Explorer
Thanks for this.
