Reformatted USB stick, now TV won't recognise it
jefwatts
Hi
I've had a Sony Bravia T?V KDL-43WE753 for a bit under a year. I've been using a USB stick to record off the TV. But the USB had some kind of error where it showed there was hardly any space on it. I deleted all the programmes but it still showed only 25 GB free out of 58.
I reformatted the stick on my PC, putting it back to the default settings, but now the TV won't recognise it. The reformatting only gave the option of "NTFS" or "Ex-FAT (default)" under File System, so I chose Ex-FAT. My TV instructions say it's compatable with NTFS, FAT16 and FAT32 but doesnt mention Ex-FAT, so I'm not sure if this is what the problem is.
Is anybody able to help me with this? Thanks.
24 ANTWORTEN 24
dutchice
@jefwatts: Can you confirm that your USB stick is a 64GB Stick?
If yes, then type at the DISKPART prompt the following and hit enter.
select disk 2
Then take a new screenshot and post back.
Cheers,
Dutchice
jefwatts
dutchice
@jefwatts Now type the following then post back a screenshot again.
clean
Cheers,
Dutchice
jefwatts
dutchice
@jefwatts Now type the following then post back your screenshot again.
convert mbr
Cheers,
Dutchice
jefwatts
I appreciate you talking me through this, dutchice!
jefwatts
dutchice
@jefwatts You are most welcome. We are here solely for members just like yourself seeking for a solution to enjoy their Sony products.
create partition primary offset=1024
Cheers,
Dutchice
jefwatts
dutchice
format quick fs=ntfs
Cheers,
Dutchice
