No AirPlay on my Bravia KD558AG
johjohns28
Member
I can not find AirPlay on my set. Can I assume it is NOT compatible with the model in the Subject box?
Is there any work round?
Thank you.
5 REPLIES 5
profile.country.IT.title
Marino.Manolo
A Workaround? An Apple TV...
Elodin
Moderator
Hey, it appears that your TV doesn't support Airplay, you can find the list of the supported devices here. You can get an Apple TV as a workaround as @Marino.Manolo said.
johjohns28
Member
Thank you gentlemen.
SkyNet404
Specialist
Just make sure to check the specs before buying a new product to see if it align with your needs or not really.
johjohns28
Member
Thank you.
