Unbelievable.
Today I have discovered that Netflix App doesn't admit 4K Streaming when BT headphones are connected to TV.
Even the home menu of the app doesn't show Ultra HD 4K indicators
As soon as I switch off the headphones, streaming returns to be available in 4K (HDR)
Solved! Go to Solution.
With the new app version 5.1.3 (build 2039) that you can install via Google Play Store they finally have fixed this problem
UPDATE
With the factory version of Netflix app, it works perfectly.
Why?
I can confirm that as of April 15th, 2018 - this is still an issue.
How were you able to regress Netflix back to the factory installed app version?
