Hi, I have a Sony Bravia 8 II. Since the latest update, I’ve been having an issue with the Last used input option. When I turn on the TV, it always switches to HDMI 3 or HDMI 4, even though I turned the TV off while watching regular TV, not using an HDMI input. I tried changing the option to Google Home. When I turned the TV off, waited a minute, and turned it back on, it correctly showed Google Home. However, when I select Last used input, it doesn’t restore the actual last input I was using. Instead, it switches to an HDMI input.
Is anyone else experiencing this issue? I’ve tried almost everything, and a factory reset is my last resort.
I also have a Bravia 8 and having problems with HDMI ports
Could be whatever's on HDMI 3/4 waking with the TV and grabbing the input over BRAVIA Sync. Test it by turning off BRAVIA Sync control (Settings > Channels & Inputs > External inputs > BRAVIA Sync settings), then switching the TV off and on. If it comes back right, turn BRAVIA Sync back on and disable HDMI control on that device, unless it's your soundbar.
My setup: HDMI 3 = PS5 Pro, HDMI 4 = Nintendo Switch 2.
All devices are up to date.
I tried turn off BRAVIA Sync and restarted TV with remote control (hold turn on/off on controller and restart). Also unplugged all devices and just turn on TV without connected devices and unplug also TV for more than 10 mins.
Now it looks like when I turn off TV on HDMI 3 or HDMI 4 and turn on I can see HDMI 3 or HDMI 4. Which is ok.
But if I turn off TV on TV channel and turn on I got same screen.
I need press TV button on remote control to get Tv channel picture.
If I tried change with remote control input to TV app I got same screen.
It looks like there are some issue with TV app. I tried clear cache but same problem.
Last option is clear data but I am worried I will need to start again scan for TV antenna.
I just delete my TV channels and run new scan for channels and it finally works.
My problem solved.
