Whatever I plug into HDMI 1 (switch or PS4) it says is on HDMI 2 and switches to that channel .... how can I stop this, i am using an ARC SOUND bar through HDMI 3 so cannot use this as an option
Hi there,
This problem could be caused by a bad connection. I would suggest disconnecting and reconnecting the HDMI cable to see if this resolves the issue.
Let me know if this helps at all.
Cheers,
Sean Mc
Hi Bear_Zeus,
I'd recommend making sure your TV is up to date first, here's a link to the latest update here.
If this doesn't help the issue, maybe you can try resetting the TV to factory settings?
Cheers,
Sean Mc
