CMU-BC1 I BRAVIA CAM
profile.country.RO.title
Dan_Persa_Boc
New
Hello
You can connect this camera model CMU-BC1 I BRAVIA CAM through an HDMI port to the TV X95K | BRAVIA XR | Mini LED | 4K Ultra HD?
If possible, please tell me how. Thanks
2 REPLIES 2
LightFoot
Specialist
Hi @Dan_Persa_Boc   It only works with certain TVs. What is the full model number of yours? You can get the instructions here https://www.sony.co.uk/electronics/televisions-remotes-selectors-cameras/cmu-bc1#product_details_def... under support and registration.
I believe that it connects via USB, not HDMI.
Elodin
Moderator
Hey, there are two types of Bravia Cams.
There is one that comes bundled with certain models, Like the A95K which connects directly to the back of the TV without any other connection or cables, you can check it here from the startup guide of the TV on how to connect it: http://bit.do/fVbuF
There is another that is sold separately and will work on certain models which is the CMU-BC1, you can check the installation guide here: http://bit.do/fVbuH and it connects via USB and not HDMI. I hope this helps
