Calling Home
angelacr
Member
Calling Home
Home adblocking DNSHome adblocking DNS
Do you think that Sony could take note? I choose to block adverts from the net. My ad-blockers are refusing  thousands of requests (the grey bands are blocked advert or viewing-data). It would be better for the World if Sony didn't do this but it would be slightly better if the software could learn to stop, for ever, asking for DNS lookups after a few refusals.  Come on Sony DON'T BE EVIL.
7 REPLIES 7
HannahEd01
Hey angelacr, what's the model number of your device?
angelacr
Member
XR-A80J
SkyNet404
Specialist
Can you really setup or add an add-block on a TV? If it's possible, how can you do it without messing the TV software?
Maybe the only way for now is to use a VPN?
CinnamonJalapeno
Member
It's Pi-hole, which is a DNS sinkhole rather than an add blocker that you install on individual devices. You run it on your local network and set your DHCP server (normally the one build into your router) to provide clients with that DNS server when they connect to the network. When the device then wants to look up a service, e.g. www.sony.com the Pi-hole first checks if that DNS name is on its block list. If not, it either answers with the IP address if it's cached, or forwards it to another DNS service to answer it. If the DNS name is blocked on the Pi-hole, e.g ads.annoyingservice.com, the Pi-hole refuses to resolve it and tells the device the domain can't be found, and so it can't request the ads.
Eskimosony
Member
Where are the Adverts on my Sony TV? I never see any...so it's seems pretty worthless...or am I missing something?
HannahEd01
Hey XR-A80J, do you mean the google suggestions? that cannot be removed, but you can rather turn the TV to BASIC TV instead.
angelacr
Member
https://www.theguardian.com/technology/2022/jan/29/what-your-smart-tv-knows-about-you-and-how-to-sto...
This is the reason I block many many Sony urls. I did post some of their URLs here, but they appear to have been removed.
