Bravia showing the wrong HDMI port for the soundbar
Connovar79
Explorer
Hi All
I am trying to connect a Sony soundbar to a Sony TV using ARC.
The ARC port is HDMI 3 and the cable is in HDMI 3. There is only one HDMI port on the soundbar (which is ARC).
No sound comes out of the sound bar at all. I have tested the sound bar with the optical cable and it works fine.
The Bravia Sync device list has two lines:
Line 1) Device = "Player 1" Input = "HDMI 1" Audio system = "Connected" Type = "HT-CT790"
Line 2) Device = "Audio system" Input = "HDMI 1" Audio system = [blank] Type = "HT-CT790"
As a test I have pulled out all HDMI cables except the sound bar which is in HDMI 3 ARC.
Please help!
Best regards
Paul
6 REPLIES 6
LightFoot
Specialist
Hi @Connovar79. The actual model numbers of your TV and Soundbar may help ...
Connovar79
Explorer
The TV is a: KD - 55XE8596
and the soundbar is an: HT-CT790
Kirsty.v.p
New
Did you ever solve this issue? I have the same models and I am having the same problem setting up mine, Thanks
Connovar79
Explorer
No.
The sound bar still comes up as HDMI 1 (it's in 3ARC) and I have to use the optical cable as well as the HDMI.
Kirsty.v.p
New
I think I’ve just fixed it! In our sound bar I had it plugged into the wrong HDMI I didn’t see the three next to each other and the HDMI needs to go in the ‘HDMI out’ on the sound bar and now it’s fine without the audio cable
Sent from my iPhone
Connovar79
Explorer
My sound bar only has one HDMI port 😞
