Advanced Contrast Enhancer issue On Sony TV's? Have you had this problem?
the screen image keeps constantly changing bright to dark when set to high/medium (Adv. contrast enhancer).
Hi there
As you can see, its not perfect. Either set it to low or off if its s concern.
Cheers
The issue is that the Picture has more depth with this feature on and better overall brightness.
I guess you just need to weigh up the pros and cons of using this feature. Can i assume you have turned off the light sensor as this can have an effect on brightness.
Cheers
