How to turn completelly off sounds in Alpha 33 ?
SOLVED
profile.country.ro_RO.title
vladtheodor
Visitor
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi viadtheodor.
Have you checked in audio settings..:smileyconfused:
MENU button [Audio signals]  Select the desired setting.
- Selects the sound produced when the shutter is locked, during self-timer countdown, etc.
4 REPLIES 4
Thalamus.
Champion
Hi viadtheodor.
vladtheodor
Visitor
Volume settings is locked.
vladtheodor
Visitor
I need to shoot photos in a very silent room.
Shutter sound is too loud and can not remove this.
You own an Alpha 33 from Sony !?
Thalamus.
Champion
:thinking:
Unfortunately you will not be able to change the volume of the shutter as this is an actual mechanical sound..:smileysad:
