Xperia 10 IV signal
Zathrus
Explorer
Xperia 10 IV signal
On my phone I cant get a signal.
The Aeroplane mode isn't on, I've taken out & put my sim back in.
Restarted & done a factory reset on the phone & used the downloadable software on sonys website to check to see if this would sort the issue but hasn't sorted the issue just wondering if anyone else has had a similar problem?
7 REPLIES 7
Anonymous
Not applicable
@Zathrus I think from what you tested with the phone it seems that it might be a SIM card issue, so you can check the network indicator in the status bar if it is empty you will need to test the SIM with a different device and if is doing the same with the other model you will need to check it with the network provider so they can help.
Zathrus
Explorer
I have tried my sim in a different phone and the sim seems to work ok in this phone.
Despite this seeming a bit odd, so I'm non the wiser
Despite having the sim for quite a while now & the sim working well on the 4G network on the network I'm on.
Anonymous
Not applicable
@Zathrus did you try to test another SIM with the phone ? Does it have the same issue ?
Zathrus
Explorer
I've tried the sim in a different phone and don't have any issue with the phone or sim being stuck in what seemed like aeroplane mode or not getting any signal
Anonymous
Not applicable
Hey @Zathrus
Try all the steps here and test after each step to check if it will work
If the issue remains, you will probably need to send your device for inspection.
Zathrus
Explorer
Again I tried all the steps in the link & done a factory reset & used sonys own app to repair/fix & or update the phone & it didn't work.
Anonymous
Not applicable
You'll need to contact Sony directly for that @Zathrus. Here's their contact info
