I am trying to play from the camera to the TV (Samsung) via HDMI.
When I connect the camera, a separate HDMI source opens on the tv which indicates that the device is recognised. But I do not get any picture or sound when replaying videos or pictures. I do have the correct cable!
Any ideas? Is there anything in the output settings I forgot?
Thanks for your help.
Hello @Henkpien,
these two helpguides should be of assistance:
http://helpguide.sony.net/ilc/1410/v1/en/contents/TP0000301891.html
http://helpguide.sony.net/ilc/1410/v1/en/contents/TP0000226673.html
Thanks Nic.
Tried that all. No avail. The Sony manual is rather poorly written with little help if things don't work. I was thinking there is some hidden setting which controls the output.
Henry
Picture sent.
Thanks
Hello @Henkpien,
thanks for taking the time to take and upload the image.
I can't see anything wrong with that cable.
Did you try to deactivate the "CTRL FOR HDMI" (Control for HDMI)?
http://helpguide.sony.net/ilc/1410/v1/en/contents/TP0000226674.html
Also did you manually set the resolution to either 1080p or 1080i as test? It says on the helpguide, that you should do that, if with the Auto-Setting your display doesn't show anything.
Yes, tried all of these settings, no change!
It does, tested it with an onther device, no problem there.
