Phone will not charge/Awful battery life recently/Overheating?
SOLVED
GRiley
Visitor
When I first got my Z5 it ran great but now only 3 months after getting this phone it will not charge.
The phone itself and the charger get ridiculously hot whilst charging and the phone runs hot when performing the most basic of tasks.
The battery life was great at first only needing to charge once every other day which I would do in the day, never over night. I now have to charge my phone atleast 3 times a day which is pathetic and now with 8% battery remaining my phone will not charge, I've plugged in many different chargers and theyre all recognised (The phone vibrates and any low battery warnings remove themselves from my display) but nothing happens. I am not brutish when inserting or removing the charger and I previously had a Samsung S4 which i had no issues with and held the same charger for the entire 2 years which i had the phone.
If anyone could explain to me why my phone will not charge or any possible fix to this issue all help would be very much appreciated. Isit possible my phone is faulty? It seems to be the top half of the phone that gets hot
Tags (2)
14 REPLIES 14
Phy
Legend
Legend
Check the app settings.
Martin1234
Visitor
I have deleted the email accounts now, because they did not sync for hours, but always tried. Will install a new email client now and see what happens then with battery life. Thanks for the effort. Moght come back when nothing changes ... Slightly_smiling_Face
Phy
Legend
Legend
Ok, not a problem.
RobertoDS
Contributor
U should configure your clients in IMAP and not in Exchange but if u need Exchange Services, it's up to you to decide what u want
But, clearly, Exchange drains a lot more than IMAP Winking_Face
GRiley
Visitor
Thanks, I managed to fix my phone after talking to my network provider after they gave me this solution!
They also helped me with my overheating issue but this did require a factory reset of my phone.
