No sound for incoming SMS messages
mrh2go
Visitor
Please help!  Incoming SMS messages are silent.  There is no sound on the phone when they arrive.  Phone ringtone and all other sounds/speaker work fine.  Is there an adjustment or setting for SMS or do I have a phone problem?
Thanks for your help.
14 REPLIES 14
Samuel1
Hero
Have you checked the settings? If you open up Messages > Settings you find the notifications settings for text messages.
Sportkombi
Visitor
i have the same problem. Settings sound sms in settings is ok, other notification sounds works. But nothing happend, phone is silent and vibration also doesnt work.
otherwise, when sms comes notification bar doesnt appear on top of touchscreen. other notification bars are ok.
regards
Rickard
Master
Also check so that notifications are not blocked for the messaging app. You can check this under Settings -> Sound & notification -> App notifications -> Messaging.
profile.country.PH.title
MarlonUk1
Sportkombi
Visitor
All application have neutral settings.
Safe Mode is exactly the same . nothing has changed. performance test showed no defects
Sportkombi
Visitor
factory reset solved the problem.
Rickard
Master
Glad to hear that you've solved it and i'm sorry that you had to reset your phone.
Please let us know in case you should see this again.
Lisse83
Visitor
I have the same... No sound. Checked all the settings and they are correct.
I don't want to put to factory settings. This phone is only a few months old.
This occurred after the last update.
Ladylost
Visitor
Same issue - don't want to factory reset.
Also just happend after an update.. Please fix this with a new update.
