- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hello , i recently splashed out on three televisions , but now i am having issues mounting them to a wall , i cannot believe i am the first person who has had these issues . I have xh 92 ( 65 inch ) xh92 ( 55 inch ) and the xh91 ( 49 inch ) , i have an installer doing this job for me , and he says that his supplier says you must use Sony wall mounts as there are issues using generic wall mounts ....... can you use a generic wall mount ? If so which manufacturer ? . Sony are recommending two wall mounts su-wl 850 and the su-wl450 , the 450 is suitable for the xh92 ( 55 inch ) , but the other two were going in the corner of different rooms and i don t think the 20 degrees movement would be enough . This is not about money , i want something fit for purpose , but it seems there are issues with which ever direction i take ..... can anybody offer an alternate solution ? . Also , when i google the 450 it seems like it has vanished off the face of the earth , i keep seeing unavailable or can be shipped direct from Japan ....... what is going on ?.
Regards Chris
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
The TVs all have VESA hole pitch dimensions for universal VESA mounts and there are no specific brands required, just make sure when you're making the purchase that it can be tested/confirmed to work with your TV and is VESA-compliant/compatible.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi , many thanks , i was thinking that myself ....... i just wish Sony would be clearer about generic wall brackets .
