Disable retail mode
SOLVED
nonontb
Visitor
Disable retail mode
Hello,
I've tried to enter any code found in the forum to disable the retail demo app.
But it didn't work !
Anyone know the right service code or procedure to disable this mode on Z3 compact tablet WIFI
Thanks in advance
Regards
Arnaud
1 ACCEPTED SOLUTION
Accepted Solutions
Thommo
have you tried *#*#73556673#*#*
15 REPLIES 15
Uliwooly
@nonontb
if the code doesn't work then return it to the store.
Thommo
nonontb
Visitor
yes, I tried this code and nothing
Regards
Arnaud
Thommo
Do you have a demo device - Dial *#*#7378423#*#* then open Service info then Software info and reply with the customization number
nonontb
Visitor
My Bad ...entering the code did work after all
I've done it at least three times. I don't know if I mistyped it before or something else ...
Anyway after entering the code correctly, the Contacts Apps closed (it didn't the previous attempts) and the retail demo do not appear anymore when charging...Great !
Arnaud
PS : On a WIFI tablet, to make the dialer appears, refer to this post :http://talk.sonymobile.com/t5/Xperia-Tablet-Z/Retail-Demo/m-p/325563#M117
Thommo
I installed a 3rd party dialer app from the play store which works just as good
nonontb
Visitor
Well, even if I manage to disable the retail demo.
The customization number is : 1290_0438_R3C
Regards
Arnau
Thommo
So according to my list the latest firmware version available to you is 23.1.A.1.28/R3C and you have the Frech Generic firmware
nonontb
Visitor
I'll keep those information
Thanks for your time and replies
Regards,
Arnaud
