I need some serious help here if possible
I just restored my laptop to its original settings and now the blessed wirless network conneciton will not connect!!!!
When I first bought the laptop it automatically picked up the router on my main computer and I was off, now it says there are no networks available!!!!
I have "Local Area Conneciton", 1394 connection and Wireless Newtork Connection showing on the Nework Connections and both the local and Wireless have a red cross on them.
I have been on the main computer looking for help on this, tried what it said about setting up a wireless connection as well as entering my WEP key but it still does not work!!!
Any suggestions please!!!
Before long I will no doubt throw it across the room as I have been trying for about 3 days to get this working!!!
Plase email your suggestions if any to debbie.kirkland1@btopenworld.com
Many thanks
Hi Debbie and welcome to Club Vaio.
I know these things can be a real pain to solve. Can you give us a bit more information? Sorry if they are basic questions.
Model of VAIO?
XP or Vista?
Make and model of Router?
Is the Router set to act as a DHCP Server and is the Vaio set to use DHCP to obtain an IP Address automatically?
Try Run -> CMD and press enter. In the black command box type IPCONFIG /ALL (space between G and /) and press enter. What is the IP Address, Default Gateway, and DHCP Server?
Does it work with a wired ethernet connection?
Is the Router set to 'Broadcast SSID'?
Have you run the Network Wizard?
What Firewall are you using and have you tried turning it off?
OK here goes
Have asnwered you questions as much as I can but I am no computer expert
Hope you can help as this is really doing my head in
Model VGN - FS 4858B
XP
Bt Voyager Wireless ADSL
Router as DHCP ???? Not sure what that is or where
IP address have tried both ways
Config :- Broadcast. IP routing enabled says NO and so does Wins Proxy Enabled
Ethernet adaptor - Media disconnected
Ehternet Adaptor Local Area Connection: Media State - Media disconnected
Both of the above ethernet also have an ip address as well as something about intel
Have run Network Wizard quite a few times now several different ways!
Says there are no networks available
Firewall is off
Many thanks
