thank you very much Elaine
Hi Harry,
Well, I`ll tell you what I THINK is wrong, but I cannot guarantee the results of following the advice below. You do so at your own risk.
Here are the items I think are wrong, so run Hijack This and get it to fix them. Then run it again and see if they are gone.
Hijack This Log
O2 - BHO: (no name) - {029CA12C-89C1-46a7-A3C7-82F2F98635CB} - C:\Program Files\Kontiki\bin\bh309190.dll
O4 - HKLM\..\Run: [websx] C:\Program Files\websx\int139749.exe auto
(Assuming you not have a legitimate "Kontiki" program)
Startup List
Autorun entries from Registry:
websx = C:\Program Files\websx\int139749.exe auto
Enumerating Browser Helper Objects:
(no name) - C:\Program Files\Kontiki\bin\bh309190.dll - {029CA12C-89C1-46a7-A3C7-82F2F98635CB}
(Again assuming you not have a legitimate "Kontiki" program)
If you have done the above try out you system and see if it is still working!!!!!
Then backup the registry and put "Kontiki" into the "Regedit Search" option and delete everything it finds.. Also use XP "Search" to look for it and put all it finds in a folder somewhere else until you see if it is needed or not.
Do the same with websx
Let me know what happens. If I don`t hear from you soon I`ll assume the worst.
Best of Luck
Elaine
Hi Elaine. i have just tried the forum, and i dont want to register.
TO VAIO USERS: Please can you have a look at the logs of HJT and Start UP, on the pervoius page, and tell me if you know which are bad and shoud be got rid of :smileygrin: :smileyconfused:: .
Thanx Again Kee-Lo. Without people like you we would not survive.
Yes, well, i suppose it did in my case!
Thank you very much. I am performing the scans now and just to let you know, a spybot from Alexia is automatically downloaded from MSN HOTMAIL !
