VGN-FE41S CPU Upgrade.
SOLVED
profile.country.nl_NL.title
keattan11
Explorer
I have a Sony Vaio VGN-FE41S laptop and I have successful upgrade to Windows 10 Pro (32-bit).
I would like to know, can I upgrade the CPU to make my laptop a bit faster?
I did some reseach and compare my VGN-FE41S with VGN-FE41Z and I find out both of them are using the same motherboard and the smae video card. The only differents is the CPU.
The CPU from my VGN-FE41S is :
Processor: Intel Core 2 Duo Mobile T5500 (1.66 GHz)
L2 Cache: 2 MB
The CPU from VGN-FE41Z is :
Processor: Intel Core 2 Duo Mobile T7200 (2.00 GHz)
L2 Cache: 4 MB
I find out there is another CPU from the same type which is a bit more faster and that is :
Intel Core 2 Duo T7600 (Socket M) CPU
Processor: Intel Core 2 Duo Mobile T7600 (2.33 GHz)
L2 Cache: 4 MB
I want to know, can I upgrade my CPU to the CPU from above, without having problems with my motherboard. Please help me.
Best Reagrds,
Keat.
2 ACCEPTED SOLUTIONS
Accepted Solutions
Blencogo
Hi Keat,
Your FE41S should take any compatible 'Socket M' processor - so T7200, T7400 and T7600 should be fine with your 945PM chipset.
The only concern is the extra heat generated, so think carefully before fitting a T7600.
The Socket M models have been discontinued for some time and you may have to search around for one.
:wink:
keattan11
Explorer
Hi Blencog,
Thank you very much for your reply. I think in this case is better I upgrade to :
L2 Cache: 4 MB
Since the VGN-FE41S almost the same as VGN-FE41Z. Do you agree with that?
Best Regards,
Keat.
2 REPLIES 2
Blencogo
Hi Keat,
:wink:
keattan11
Explorer
Hi Blencog,
L2 Cache: 4 MB
Best Regards,
Keat.
