Hi all, I have been having terrific problems with the inbuilt camera on my Vaio Laptop. The camera has been working fine since purchase, and have been using Norton 360 as the Anti-virus/Network protection option. All has been fine until recently.
After a series of Windows Vista updates and Norton updates, when invoking the Vaio Camera Capture Utility, the application fails to initialise the camera as it may already be in use. No other applications are running.
I have restored the system to an earlier point and the system does function correctly. When Norton starts to update itself, the problem reoccurs.
Has anyone else seen or experienced a similar issue/problem and found a solution? Any assistance or guidance would be appreciated.
Mike B
Hi Thalamus
Many thanks for the advice. The Vaio Model is VGN-FE48E.
I have run the microsoft fix that you posted, and it appears to have worked.
Once again, many thanks for your help and advice
Cheers for now
Mike B
You're welcome Mike..
