After Deinstallation of some VAIO Components I don't need, I did not have access to the Touckpad Control Panel. I couldn't find it anywere. The APoint Drivers work probertly,but I couldn't adjust the Touchpad. I try to install the Apoint Drivers new, but the System said there are still installed. Where can I found the Touchpad Control Panel ?
Hi Kulminator,
Welcome to Club Vaio,
You need to download the pre-installed utilities from here, as I'm fairly sure you need to re-install the Setting Utility Series.
However I'm not 100% sure whether you have removed any other Vaio utilities, therefore you may need to re-install some of the other utilities as well..
If that doesn't work, try downloading the Alps Drivers and the Control Utility from HERE
