Hi all,
The last couple of days I have the following message come up on the BIOS screen on my Sony Viao PCG-FR285M: -
"SMART failure predicted on Hard Disc 0: HITACHI_DK23EA-40-(PM)
WARNING! Immediately back-up your data and replace your hard disc drive. A failure is imminent."
Once I hit F1, the laptop runs through normally, after a minute or so, and then nothing seems untoward. I'm quite annoyed, as the hard drive was replaced by Sony (under warranty) in June 2004, but my standard warranty has run out.
Any ideas as to why this is occuring? The laptop has only been subject to normal usage, with good anti-virus software in place. Do I have a case with Sony?
Thanks for your advice in advance!
I would do as it says, well at least back up your data, maybe then do a complete restore, and then hopefully you can keep using it and have no problems, but have the back up if the hard drive does fail. If the hard drive was replaced over a year ago you are probably well out of any warranty meaning that extracting anything from sony will be as difficult as extracting blood from a stone.
Yes,if they are System Restore disks you make.Keep an eye on your Hard Drive,it is possable that it is just a read error that Smart is detecting,Computers do sometimes develope Ghosts occasionaly that come and go.However,I would Scan your HD for any Bad Sectors,if it finds any,then its definatly on its way to sudden death.The only solution would be to buy a new HD and put it in.
Go to Majorgeeks.com and download one of the free diagnostic apps available.If you know what hard drive is in,then go to the manufacturers site and download the Drive maintenance software they provide.
I would definately back that drive up though, that's priority #1
Hi tonywitney,
he process looks fairly simple, but will the information contained on the back up discs include Windows XP, other loaded software and all the stuff from My Documents?
Hi tonywitney,he process looks fairly simple, but will the information contained on the back up discs include Windows XP, other loaded software and all the stuff from My Documents?
The backup disks created using the Vaio Recovery Utility will only return your system to “as delivered” – this will not include any third party programs that you have installed since purchase, or any documents.
There is no alternative for third party programs other than a re-install after the recovery process.
You can move My Documents to the C drive prior to restoring and during the restore procedure only choose to re-format the C drive. I would make a backup anyway.
Generally speaking any hard drive up to 80 GB with the same form factor (2 ½ inch) will fit and work in your model. Definitely go for a 7200 spindle speed.
