I have the new Vaio Laptop VGN-AR21S with the blu ray drive. When I try to play my legal blu ray disks and connect with the HDMI output with another display with the bundled WinDVD for Blu Ray, a message comes out stating that the protected content cant play with these settings. When I try to play ordinary DVDs with the exactly same settings everything is allright. Except one does not buy a blu ray laptop to see on his plasma display ordinary DVDs. Anyone, the Sony Vaio moderator maybe, can Help? It will be much appreciated.
Hi Tassos and welcome to Club Vaio.
Make sure you have the latest firmware update for your Blu-Ray drive - check HERE
I also understand there is an update for WinDVD BD - open it and search for updates.
That's strange - you did download the update for your particular drive?
Try a system restore to the most recent restore point before today: -
Start -> All Programs -> Accessories -> System Tools -> System Restore
Click on 'Restore my computer to an earlier time' and pick the most recent restore point available.
Let me know if that works.
I have an AR11S and when i use the LCD as only monitor it works, but if I use twin mode it doesn't. But for me this is not a problem.
My Problem is if I configure under timings the LCD as 1080i, it's flickering and it saves 60 Hz and interlaced is not marked?
Is your TV HDMI compliant.
I can play blue ray over HDMI, but not VGA or SVIDEO.
The TV has to support HDMI protected content I believe..
