I have a vai z1, and the dvd combo drive stopped reading dvds about a week after the warranty expired, so i can't use the bundled recovery dvd to restore the laptop.
However, i have an external dvd drive, (USB) so i created a boot disk with nero and as my laptop can still read cd's, i used it to boot into dos with usb drivers. Now i can browse the vaio recoverey dvd, but i can't get the recovery app to run.
is there anyway to initiate the recovery through dos? please bear in mind i don't really know dos at all so dont have a great idea what i'm doing.
so, i browse the dvd in dos using the only command i really know, 'dir' and i can see the recovery.exe app. however when i run it it says it can't be executed in dos.
thanks in advance anyone who can help!
Doesn't your laptop has a hidden partion with the recovery data? You can get it to restore your system using the restore utility program installed... :smileythinking:
nope!
I have an SZ Series but cant check now because I'm doing a few things on it...
In the BIOS, does it have an option to boot from a USB device?
That would be one way I guess... I dont know if you can do it via Dos Prompt itself as theres no exe from what I remember.
Hi smanger,
When in dos, in F: (F being your cd/dvd drive) do you have autorun.exe...
Even if it is available from DOS, autorun.exe is an executable file designed to run under Win32 code. The only way that i know to run Windows code from within DOS is to "hack" into the DOS internal code using assembler instructions. It is a bit tricky and too risky to be tried out. It can damage the computer...
Maybe it is possible if something like Wine would exist for DOS...
autorun.exe cannot be run in dos mode...
i can see all the files on the recovery cd, i just can't run any of them. when i open the cd in windows, it says click to reboot, then the installaiton will begin. i take it because i dont have the dvd in the main drive, i can't do this. somehow, i need to make the external dvd drive boot.
