I've had my Vaio for about 3 years and had no problems until recently. I use it a lot and now find that the fan gets noisy after time. What can I /what should I do about it?
Hi nicobobulous,
welcome to Questions & Answers..:smileyhappy:
The cause could be a build up of dust, you could try cleaning the vents with a blast of compressed air (you should be able to get this from your local PC shop), check the instructions on the can before using because if used incorrectly you could damage the fan..
