can i run sony vegas on my rather old sony vaio PCG 8U1M?
profile.country.en_GB.title
richardglastonbury
Visitor
My old sony vaio PCG 8U1M has had its hard disk reoplaced and so i no longer have the original vaio operating system running - instead runnning on windows xp - but its my only computer with fire wire connection and i want to edit videos using sony vegas - i cant find the laptop specs anywhere (and the stick on specs on the case have worn off! - so what i want to find out is can I run the latest sony vegas software on it or is it just too limited and slow and instead do i need to buy a new lap top with firewire?
Tags (6)
2 REPLIES 2
Blencogo
You can't find the specifications because you are not quoting a valid Vaio model - you are quoting a chassis number which is shared by several models.
Have a look on the screen surround for a different model number - I think you will find you have something like a VGN-A517S and the specifications can be found on the support pages for that model here: -
http://support.vaio.sony.eu/computing/vaio/specifications/index.aspx?m=VGN-A517S&l=en_GB
What version of Sony Vegas are you wanting to use and will the video be HD?
:wink:
richardglastonbury
Visitor
Thanks Blencogo  for this - now I see it is a VGN A517M - not sure which version of vegas as I have not got it yet - not HD as I'm filming with a SONY PD170P DV/DVCAM. Anyway I have looked up specs with this model number....so that's been useful, thanks
VGN-A517M
Genuine Windows is authentic Windows software that is properly licensed and legally installed. Learn more about the special benefits reserved for genuine Windows customers by visiting www.microsoft.com/genuine.
Operating
  • Operating SystemWindows XP Home
  • Service Pack2
Technical Platform
  • ArchitectureIntel 915PM
CPU Section
Memory
  • Memory Size (MB)1024
  • Memory Speed (Mhz)533
  • Memory TypeDDR2 - PC2-4200 (SO-DIMM)
  • Max. Supported Memory (MB)2048
Display
  • Diagonal Size (in)17
  • Resolution1440 x 900
  • Resolution TypeWXGA+
Graphics
  • Graphic Card NameATI Mobility Radeon X600
  • Total Graphics Memory (MB)128
Multimedia
  • Audio ChipsetALC260 - 2-Channel High Definition Audio Codec
  • Chipset ManufacturerRealtek
  • Audio TypeAC Link
Drives
  • Hard Drive SATA (GB)100
Optical Drives
  • Optical DriveCD x24, CD-R x24, CD-RW x24, DVD x8, DVD+R x8, DVD+RW x8, DVD-R x8, DVD-RW x6, DVD DL x4
Interfaces
  • Memory Stick™ SlotMemory Stick™ Standard, Memory Stick™ PRO
  • USB Port(s) (quantity)3
  • USB SpeedHigh/Full/Low
  • USB Version2.0
  • 4 Pin i.LINK (IEEE1394)1
  • Headphone JackYes
  • Microphone JackYes
  • TV OutYes
  • VGAYes
  • Docking Station ConnectorYes
