suddenly when i watch channel 4 it is not showing adverts but instead a little green waiting circle. It seems to get stuck on this circle often and doesn’t go back to the programme after the adverts must have ended. Also when I try to play a programme on channel 4 the little green waiting circle comes on and won’t play the programme. My tv uses Sony select for channels bbc1-channel 5. I’ve tried factory reset, emptying cache etc. please help it’s really annoying! I’ve gone as far as paying for channel 4+ to avoid the adverts to see if that helps but it hasn’t!
Hi @Milajayne,
Did you try to disable the YouView app? Press the Home button > Settings > Channel Setup > YouView Setup > Disable > Yes.
Then try enabling it back again. Press the Home button > Settings > Channel Setup > YouView Setup and follow the screen instructions.
