Sony KDL 46W5810 bbc iplayer problem - error "This Content doesn't seem to be working. Try again later
Hi All
I have 46W5810 with freesat hd
im on virgin broadband , around 7mb download adsl sefvice
bbc iplayer works fine on laptop and ps3
this was working ok before on 2mb, max 4mb , tiscali broadband
i have done full tv reset
i have latest tv firmware
i have refreshed my network settings numerous times
i do access bbc iplayer by pressing red button on bbc channel
then i can see program list and some description of the program, at the same time i can see netowrk activity on the network port where my tv is connected
once trying to play it i have above error
the bbc iplayer list constantyly update itsels once new programs there
i can play hd movies from PS3 Media Server from my laptop on that tv
please advise as I don not what to do next!!!!
Solved! Go to Solution.
no jocardy . ...
im still receiving error "This Content doesn't seem to be working. Try again later
all other like ps3 , 2 laptops , 1 desktop , mobile phone are ok....
Hi All
Im still having the same issue after 1 year on 😞 BAD SONY
Regards
Hi there
Unfortunately I do not believe this is a Sony Issue. However, lets try and take this from the start. How far do you get from the following?
If you have connected your TV up to the internet, and can confirm that (as other internet services should work).
Goto a BBC channel (as in BBC1) on Freesat and press the red-button. Does the menu pop-up with something similar like the screenshots on the following page?
http://www.bbc.co.uk/blogs/bbcinternet/2010/11/new_red_button_connected_homepage.html
Now go into BBC iPlayer. It should then load up the iPlayer. Now play a test program of any kind.
Can you confirm how far you get, and at what point it fails?
Cheers
Hi Quinnicus
Firstly I would like to thank you for your reply J
OK..I do get as far as to the BBCIplayer page and then I have the latest shows which I can browse on the screen and then when I chose any of them, buffers and displays error ‘This Content doesn't seem to be working. Try again later 😞
This is what is happening, no more….
BTW BTW here is a screenshot of the error
@tom.74 wrote:
Hi Quinnicus
Hey there, no probs
Firstly and foremost - I dont have the answer for you...
I have a PVR Recorder (HDT500B) that also uses the BBC Connected Red button service to access the iPlayer (via FreeView). I have just tested it on mine (as I dont use it this way) - and it works, no problems at all.
On the BBC website : HERE - It states the following devices are iPlayer certified. However, this appears to be the application. I cannot find a website that has iPlayer certification via the connected red button. Googling this does not bring up anything relevent to you.
Your best bet is to contact the BBC itself to try and ascertain whether the connected red button service via freesat is still available for your TV.
I say the BBC (and not Sony) because this appears to be an internal application issue, of which its totally out of Sony's hands.
All I can say is - Good Luck
Cheers
thank you
BTW, TV is freview/freesat unit and BBCIplayer work via freesat option
I do belive that my TV has been somehow discounted from BBCIplayer service by BBC and there is no updates due to HW limitations from Sony for that 😞
I just would like to know if there is anyone with same issue on the same TV, surely Im not the one with that unit...
PS my laptop, ps3, sony bdp all of them on lan or wifi they ar ok
not a TV 😞
Are you running the latest firmware on the TV?
http://www.sony.co.uk/support/en/product/KDL-46W5810/updates
Worth checking that, then try doing a factory reset and power cycling (unplugging from the mains for a couple of minutes) your router. This should force it to get a fresh IP address and so in effect flush any legacy gremlins which might have been blocking it. No reason why it shouldn't work.
Hi Catmambo
Yes I do have latest firmware which is quiet old now 😞
Could it be that Virgin broadband is blocking this service to force me to use their equipment or issue with a codec on my TV
I know that other like ps3 or sony bdp are with latest firmware and bbciplayer viewer application
I know that bbciplayer is delivered via few different vide/adio codes
http://www.bbc.co.uk/blogs/bbcinternet/2008/08/bbc_iplayer_goes_h264.html
😞 not sure where to go with that 😞
