Bravia KDL-32HX755 does not recognize 3D
profile.country.sv_SE.title
arnebergsson
Visitor
Hello,
when I receive 3D signal it is shown side-by-side, rather than in 3D. In settings -> display -> 3D settings menu, in "3D display" item, I can only choose "off" or "simulated 3D". I cannot choose "side-by-side" or "over-under", because it is grayed out.
I tried "auto 3D" set to both "on" and "off", but neither helped.
Does anybody have a similar problem?
Thank you.
Arne
3 REPLIES 3
Anonymous
Not applicable
Hi there
Without knowing much about your setup (as in how you are playing 3D content), the first thing to check is - Are you using a HDMI cable that supports 3D signal. You need HDMI 1.4
Cheers.
arnebergsson
Visitor
Hello,
it is cable 3D broadcast, not from an external device over HDMI. The signal is clear, I see side-by-side picture.
Arne
arnebergsson
Visitor
I should have added that it is using a built-in DVB-C modem in the TV set, no external cable modem.
A.
