Xperia Pro MK16A File transfer not working after 4.0.4 update?
SOLVED
AviatorAndrew
Visitor
Hello, I've been at this problem for some time now and I have no clue what has happened. I simply connect the USB to computer and phone, Click Start in PC Companion (in File Manager). I drag and drop my pictures from 'My pictures' to 'images' and the pictures does appear in the folder of 'image' but once I disconnect the USB so I can access the photos in the phone, it's nowhere to be found. I'm not sure what's wrong with the card or the phone, I've tried deleting pictures from the folder ('image') that I open in the computer but once I disconnect to check if the images I deleted are gone, they are still there. It's like the SD card is not even connected or being read by my phone? The weird part is that it use to work before I updated the phone to 4.0.4. The file sizes and formats are identical... Music and other files don't show in the phone at all either.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
Also try this great gallery app
QuickPic
https://play.google.com/store/apps/details?id=com.alensw.PicFolder&feature=nav_result#?t=W251bGwsMSw...
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
someone is trying to hide the facts
http://talk.sonymobile.com/message/244573#244573
http://talk.sonymobile.com/thread/54167
20 REPLIES 20
Uliwooly
on your phone, download OI file manager or Astro file manager > go to the folder where you transfer the pictures > do you  see them?
AviatorAndrew
Visitor
Ok, It shows in OI File Manager and Astro Manager. I clicked one of the pictures then it asks what to use to open the file or w/e ('Gallery' and 'Xperia Gallery' > I chose Xperia Gallery) but the file number count hasn't changed and the pictures don't show in the gallery... I can clearly see it in the managers but not in the actual gallery! Slightly_frowning_Face
Uliwooly
try this
settings > apps > all > album > scroll down > clear cache > restart your phone and check again
Uliwooly
QuickPic
Uliwooly
you can also try the Xperia S gallery app (it only works with ICS)
http://talk.sonymobile.com/thread/38259
AviatorAndrew
Visitor
I found 'Gallery', 'Xperia Gallery' but no albums and all of which didn't allow me to clear it's cache... I've also tried restarting my phone, no different results.
AviatorAndrew
Visitor
Yes! QuickPic works! I'll try and add more photos if it does really work, thanks a BUNCH! If you're not annoyed yet, could you explain why this happened? It works with another app but not with the actual system!?
Uliwooly
it's probably a bug that it's not recognizing those pictures, where exactly did you transfer them? to the DCIM > 100Astro folder?
AviatorAndrew
Visitor
I transfer all the pictures from my computer to 'images' after I click 'Start in File Manager > (In PC Companion).....
edit: Also, It's working! Thank you!!! I guess I'll just have to keep opening QuickPic :smileyhappy:.
