Hello Sony and all Xperia users.I have a weird problem with my Sola (MT27i) ! I'm from France and I want to update my smartphone to Android 4.0 ICS but I can't!!! Now I have the 2.3.7 Android version and the Build Number is 6.0.B.3.184. Everytime I connect my phone to my computer, PC Companion says that my Sola is up to date.How can I update my phone?
Solved! Go to Solution.
you have to wait for it to be approved in your country
this should explain it
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
if i understand it correctly you will have to lok for your SI number. it is on the back of your phone printed on the battery.
then you have to look in this blo fotr a list meade biy Jeff. search your number if its on the list then you can update your phone accordingly with the dat. No matching SI number? you'll just have to wait and keep your fingers crossed.
if you can not wait then
How to manually update 2012 Xperias to android 4.0.4
http://talk.sonymobile.com/thread/41609
Thank You very much for this! I was worried about my Sola update but now I'm relieved :smileywink:.And it seems that I have two choices : 1.Wait for my update with PC Companion. or 2.Make the manual update.
Thanks!
anytime
Thanks for the advice but...I don't have any luck.I can't find my SI number.:smileysad:However, thanks very much for this!
Here you can find info, how to detect your SI number (and not only that) http://talk.sonymobile.com/message/296748#29674
Thanks, but I can't find my SI on that list!
It just means that you have to wait. Mine SI in not there as well.
