Why can I update to JB?
SOLVED
Lan_Ed
Visitor
Having a Xperia J and having heard that a JB update was released, i tried an update using Companion......for my amazement, although my release is 11.0.A.7.8, Companion just said....."Your phone is up to date"......I thought that Companion had some problem so i went to sony's web site and tried to update from there......."Your phone is up to date" was the answer......
If the latest available software is the 11.2.A.0.21 release...how can my phone be up to date?
How can i make this update happen in my phone?
1 ACCEPTED SOLUTION
Accepted Solutions
eon1221
Visitor
I have the same problem. Probably it's not a global release.
3 REPLIES 3
eon1221
Visitor
kalleklappstuhl
Visitor
updates like this are usually released in waves. Just wait a bit, you'll probably get the update within the next week. I'm also waiting for it.
Uliwooly
after the update is released it still has to go through an regional/carrier approval, you can read about it here
this should give you an idea
from source code release to software upgrade
http://developer.sonymobile.com/2011/12/07/ice-cream-sandwich-from-source-code-release-to-software-u...
