Please help... After updating facebook, i cant connect to timescape facebook, always saying could not connect to facebook everytime i refresh timescape,
Solved! Go to Solution.
it seems to be a facebook issue
http://talk.sonymobile.com/message/336897#336897
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
so the problem is on facebook...? thanks uliwooly
anytime
Definitivo .... solucion Timescape-facebook urgente porfavor xperia p Mismo Problema
Is there any news about this issue??
Encontre una solucion para el problema del timescape con la sincronizacion con facebook. Seguir los pasos a continuacion:
1. Borrar datos de la aplicacion de facebook (creo que esto no es necesario)
2.Descargar un archivo que se encuentra en este link https://www.dropbox.com/s/f8oc9cg07143blu/Timescape%20AX.rar
3.Instalar el apk EventStreamPluginFacebook.apk.
Con esto deberia funcionar, a mi me funciona perfecto
Gracias carlos360, pero ademas de eventstreampluginfacebook.apk tambien instale eventstream.apk por si las moscas y ahora trabaja perfecto! ya puedo ver mis updates en facebook!
Sony has provided the facebook extension update on play store here- https://play.google.com/store/apps/details?id=com.sonyericsson.eventstream.facebookplugin Install and everything will be back to normal.:)
LINK:
http://talk.sonymobile.com/thread/109927
Timescape stop working after FB (Facebook) 2.0 update
1) Download this file
2)From this site:
http://talk.sonymobile.com/message/336977#336977
3)Send "EventStreamPluginFacebook.apk" file to yourself via Gmail.
4)Open Gmail at your phone and install file.
5)Timescape fixed!
