Hi, I want to report that Timescape does not work in my Gingerbread XPERIA sola a few days ago...
I did try:
1. Restart Phone
2. "Clear Data" of Timescape services
...and given with No. 2, I doubt that Master Reset the phone as well as updating the phone to ICS would do anything good...
...as it turns out that ICS XPERIA sola's user also has this problem...
http://talk.sonymobile.com/message/335670#335670
Adding my comment...
I think it's a server error (not sure Sony's or Facebook's)... Please fix it as soon as possible...
Regards,
Trubo
Solved! Go to Solution.
Thanks for the solution....
Hi Support Team!!
Can you guys confirm that the update being rolled out is for ICS devices or Gingerbread devices?
Hi..i have some troble in xperia sola Timescape facebook extantion...
I,'m using Andriod Gingerbread(2.3.7) my timescape facebook intergration not working..
It's gave a Erro msg(could not update facebook account plz try again..
do u know this case should be correct..
but i'll try menually install facebook extanition..just i can't becouse cannot prassing file..
plz help me..
An update for facebook problem has been rolled out by sony.
Check once??
Sorry guys...
It appears that the update is for Ice Cream Sandwich XPERIA sola 😕
That explains why that error "Parsing error" appears as it needs ICS framework to work with...
By the way MouinChristy is right, update is available in Google Play right now!
https://play.google.com/store/apps/details?id=com.sonyericsson.eventstream.facebookplugin
But still it's for ICS only
Regards,
Trubo
