SUS Firmware
SOLVED
HussainQuadri
Contributor
SUS Firmware
I would like to know where SUS saves it's firmware for devices because I saw that everytime I have to restore my Xperia SL, the firmware does not have to be downloaded and is installed straight away. I couldn't find the firmware anywhere so I was hoping I could get an answer here.
1 ACCEPTED SOLUTION
Accepted Solutions
mandeep148
Visitor
Go to sony Mobile Firmware folder in your windows partition PROGRAM FILES
firmware is in UPDATE SERVICE  Folder,
Go to DB then go to 13740270 like Folder, then open it, then open Blob_Fs then Copy the Three largest Files in Blob_fs Folder...
DON'T FORGET MARK ANSWER AS CORRECT
2 REPLIES 2
mandeep148
Visitor
Thommo
This may explain where it saved as mandeep said and how you can create your own ftf file for manually flashing http://mytechencounters.wordpress.com/2012/06/12/how-to-create-an-ftf-file-of-your-xperia-ics-firmwa...
