I have flashed my phone with the French ICS From here
http://forum.xda-developers.com/showthread.php?t=1918920&page=1
And now I want to go back to my original Arabic Firmware.
Can any one help me and tell me how to get the original Arabic Firmware.
My phone "SI 1261-8812"
Thanks
Solved! Go to Solution.
are,namahdud daram.alan ICS ro gozashtam vase dl,dustam nete 1mb/s khodesho bem gharz dade.ta 1sa@ dge ICS dl mishe vali Flash Tool ro mundam cheka konam
Middle East zud miad,akhe faghat Iran nis,age Iran bud ke omran ina midadanesh :smileyhappy:)))
If you wait couple of days,official ICS will release to Middle East Xperia U and you can use Arabic Language.but if you really want to root it,do it.but if you are did it before and know about how
I have done it
I updated to ICS (the French version) and then Root it.
And the I edited the build.prop file, change SI to (SI 1261-375) It's the Arabic Customization
And I forced PCC to update (actually downgrade) It downloaded the files but didn't flash them
I took the files and used the flashtool and created a .ftf file and the flashed it.
And now I have the original GB .184 with Arabic Customization.
^_^
I have 2 questions:
1- what is the SI key? I installed Australian ROM (without baseband) and chnaged the phone from ST25a to ST25i in the build.prop but I can't find the key you mentioned.
2- How do you updated your unlocked boot loader and rooted phonee with PCC?! I tried PCC and SUS and both of them give me an error that "I am running custom ROM"
Thank you
1- SI (service Information) it's a number that define the region which this phone is made for. You can find yours under your battary.
2- becasuse you unlooked your bootloader you void your warranty and you can't update using SEUS or PCC. I don't know if you locked it again will it work or not. But I guess you should forget about PCC and SUES and wait for the stock ROM and flash it using .ftf
if you have build.prop copy from any official version of Xperia U (SI 1261-8812) I hope you give me a copy.
Thanks
You said that you updated to ICS french version and updated build.prop (which need root access), so I believe you have unlocked bootloader too, right?
I want to know how did you got the downgrade to .184 with arabic customization using PCC?
I hope after you get official ICS (middle east version) to create .ftf file and send the link here.
Sadly i don't have any original build.prop, what is the correct SI code for arabic, SI 1261-375 or SI 1261-8812?
You don't need an unlocked bootloader for root access as of ICS, Bin4ry over at xdaDevelopers has written a method which takes advantage of adb restore on normal handsets, and the backup/restore app for Sony handsets.
No you can root your phone without unlock your boot loader
And I got the official firmware following these steps:
1- I flashed ICS the french version
2- I rooted my phone using flashtool
3- I edited my build.prop changing every 1262-1120 to 1261-3759
4- I connected my phone to PCC and made repaire Phone which downloaded the firmware files
5- I copied the files from C:\ProgramData\Sony Ericsson\Update Engine\db\13740270\blob_fs and used the flashtool to create .ftf file
I tried using 1261-8812 which is my SI but it didn't work that's why I am looking for the original build.prop to see it's detailes.
I can upload the ftf file I made for you. It's a Middle East Customization which supports arabic and parsian.
wow, u really did a lot of work there, nice going..:smileyhappy:
This is the Original Stock ROM .ftf file for st25i 6.0.B.3.184 Middle East version which supports (Arabic and Persian ) 1261-3759 customization
Part 1: http://www.mediafire.com/download.php?ibjkyynwa6v21w1
Part 2: http://www.mediafire.com/download.php?qm8aaqjcm5qquwl
There is another customization for United Arabic Emirates 1263-4673
and another one for SAUDI ARABIA 1261-3763
I think of downloading them and try them. But I think I'll wait for the ICS firmware
