my sony xperia go st27i went dark all of a sudden and don't wanna start
SOLVED
graph
Visitor
hi , i have a sony xperia go st27i and i was talking on the phone then right after for no reason it went dark , i try to start it but nothing , even when i plug it in the charger nothing , i tried hard reset but also nothing , i can't even remove the battery and put it back cause it's built in , can anyone help
Thank you very much
Tags (5)
1 ACCEPTED SOLUTION
Accepted Solutions
DavidH2000
Visitor
hey try to press vol up and on/off button down to the phone have vibrate 3 times.......(15 sek or so)
4 REPLIES 4
DavidH2000
Visitor
Uliwooly
Connect the phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2 or 3 hours > the repair it with PCC
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Uliwooly
If PCC doesn't work then you will have to contact your local Xperia Care
http://support.sonymobile.com/global-en/contactUs/
graph
Visitor
Thank you so much , it's working again
