my lcd screen is displaying in negative
SOLVED
yahaha462
Visitor
i dont know why but since i replaced my keyboard membrane my lcd decided to display in a very bad contrast and the screen goes almost negative effect inverting the colours how ever in the menu it reverts back to normal when i make the icons hover to change them about i have no idea what it could be has any one else had this problem before ??? can you offer any advice, i cant send it to sony as the warrenty ran out ages ago thank you Slightly_smiling_Face
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
you have 2 options if its a hardware issue
1) take your phone to a Sony repair center
or
2) do it yourself, the later its a lot cheaper and not that complicated
here is the teardown guide
http://forum.xda-developers.com/showpost.php?p=6368979&postcount=82
check ebay for the LCD & Digitizer for the X10
Don't forget to mark the Correct Answers & Helpful Answers
7 REPLIES 7
yahaha462
Visitor
i have included some pictures here for you to see
1 st one is the home screen as you can see very dull and thats with brightness turned up
2nd one menu after i hit rearange icon button bright vivid display again
and then theres the inverted colours
Uliwooly
seems like a hardware issue, I see that the digitizer/touchscreen its cracked, perhaps the LCD its damaged.
Uliwooly
you could test your screen with service menu
1) Service Menu
http://talk.sonymobile.com/thread/24534
or
2) download this app "Xperia Diagnosis"
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.functiontester&feature=searc...
Uliwooly
or
yahaha462
Visitor
yeah im thinking only way forward is a new screen, i applyed a new theme and all the menus were great bar the home page and when it went to original sony xperia theme it was all messed up again so im going to try to install a new version of android and see if it clears because the screen still displays the menus fine. worth a shot, first i have to solder a new usb port to the motherboard as that has gone too then i should be able to update the phone Slightly_smiling_Face i will let you know if it solves the problem if not new screen it is not to pricey of ebay :smileygrin:
thank you very much for your help appreciated :smileygrin:
Uliwooly
let us know how it goes
yahaha462
Visitor
will do :smileygrin:
