message inbox not properly ordered
Nicht anwendbar
i just bought xperia mini pro last week.
n now i've problem with the message order..
everytime i received  new message i've to scrolled up to see new msg, not like usual as the latest message will be directly shown on the screen.
can someone help me pls? thanks Slightly_smiling_Face
uliwooly-wooly
Legende
anytime, you don't have to remove the SD card since the app remains on the Internal Memory. when you exit this or any app don't press the home button, press the back button
don't forget to mark the correct and/or useful answers
4 ANTWORTEN 4
uliwooly-wooly
Legende
ok, turn off/on your phone and check if it's solved
uliwooly-wooly
Legende
I would suggest this methods to
settings -> privacy -> make sure both options are selected (backup and auto)
other methods to backup
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Nicht anwendbar
i'd just turn off and re-insert back the memory card n all that, then turn on the phone back and it's work! btw, thanks a lot wooly Slightly_smiling_Face
uliwooly-wooly
Legende
