Hello!! Im Wondering whyi cant see my notification lights after the update to JB?? is it normal??
if i have a same question from other post, please tell me so i can remove this,, THANKS!!
Solved! Go to Solution.
Go to your messages,press the third button on the illumation bar(the settings button) and tap settings.see if the notification light is ticked.
I am having the same problem, everything is ticked, but it's not working as it used to be.
thanks my friend
Are you on stamina mode?I have seen that it disables some stuff.
You are welcome!
I was, I turned it off now.
Check the LED now.
sir, how can i change the color of the notification lights?
It's still flashing only in white.
