ICS updates Stucks at Preparing Computer for Software update..
SOLVED
session
Visitor
I Started ICS update for Neo V, but from one and half hour it got stuck at Preparing computer for software update.
and by using update service i get S1Boot download driver problem. Driver installation failed.
What is S1Boot download???
27 REPLIES 27
session
Visitor
Its there in the list of SUS... look closely
or try this newer SUS
http://www.sonymobile.com/global-en/tools/update-service/
Not applicable
Now, my update stuck a bit ahead of where yours had stuck, from past 3 hours Slightly_frowning_Face
Please, gimme a solution. I watched this system in my friend's LWW. And I want it. 😕
Not applicable
Hey dude, I think, yours is the best way to do it. My updating through PC companion stuck 4th time in past 2 days.
and I wanted to ask you...
My system apps, data on SD card and my gmail ID setup will vanish using update service? or They will be as it is after updating to ICS from gingerbread of my SE LWW.
and What if internet connection breaks while updating or some kind of disturbance occurs while doing updation through update service? :smileymischief:
Uliwooly
turn your firewall and / or antivirus off
Don't forget to mark the Correct Answers & Helpful Answers
gwhispererz
Champion
Hi Mayur, only phone date will be completed erase when you use Update Service, SD card is not affected. As for disconnection of internet during phone update, no problem .... just repeat the process again. Anyway .... a better solution is to find a reliable internet connection. :smileymischief:
Not applicable
Yeah. I couldn't help myself from waiting to use ICS and updated it through update service and used option 'factory reset+update'. (factory reset erased all phone memory).
and My connection got disconnected thrice & I was happy to know that I could continue from where I was interrupted. and later I fell asleep and when I woke up. I was having ICS :smileygrin:
Update Service is better than PC companion. Slightly_smiling_Face
Thanks dudes Slightly_smiling_Face
And thanks Android and Sony.
gwhispererz
Champion
No problem .... Glad that your phone is updated!
Not applicable
help..... im about to do a repair for my xperia u as per the advice from contact center and now im stuck w/ preparing computer w/ software update.... what to do? plsssss
gwhispererz
Champion
Don't panic .... just re-do the process.
If you are having problem with PC Companion, try Sony Update Service. Here's the download link, http://www.sonymobile.com/gb/tools/update-service/.
Not applicable
will sony update do the fix for my prob w./ the camera for my xperia u because there a violet light on my camera
