Default home panel has changed
SOLVED
nickmidgley
Visitor
Hi there,
My default home panel has chaged from the one in the middle to the fifth one, on the far right.
Any ideas how to change it back - I'm stuck!!
1 ACCEPTED SOLUTION
Accepted Solutions
Nabeel
Master
Tap and hold anywhere on the homescreen until you get the panels of homescreen
There you'll find Home option on the top left corner, tap on it on the desired panel to set as homescreen
3 REPLIES 3
nickmidgley
Visitor
I'm on an Xperia T running Jelly Bean, BTW...
Nabeel
Master
nickmidgley
Visitor
Thank you - I'd just figured it out myself!
