Can't see recent calls SONY S ICS Update..
SOLVED
Rachitha
Visitor
I discovered that i can't find recent calls from my phone. After ICS update it happens. Please i need help imediatly ..
1 ACCEPTED SOLUTION
Accepted Solutions
Nabeel
Master
Can you post a screenshot mate ?
Same screenshot as i posted above ?
You can take screenshot by > press and hold, power button + volume down button at the same time and hold them there until you take a screenshot
You're not following the steps correctly.
Go to Phone app, then you'll see the phonepad / dialpad as above.
Once you reach there, then press on this button > as shown below, then you'll see the option of show call log
Letme know how it goes
9 REPLIES 9
Karan_wolverine
Visitor
can you post a screenshot that where and how you are trying to open it and what is the error while doin so?
Nabeel
Master
First of all I hope you selected only to update and not Factory data reset+ update option in SUS or PCC
If selected the second, then you're call logs are gone.
If that's not the case, then simply do this to see if your able to get it.
Phone > tap on menu button > show call log
Rachitha
Visitor
Hmm well sorry for not having screen shots.. But normally call log appears in menu right ?? What now i can't see it in menu. It dissapeared. Even after i go dial pad, there i see only tabs which shows contacts ,favourites and Group options . I can't find the option to on CALL LOGS Slightly_frowning_Face
Rachitha
Visitor
I am not the one who updated to ICS. I got the phone already updated. Can't i get call log option back? m confused .. plz help me
Nabeel
Master
Actually it comes at this place now. Just above the phonepad.
And if you're not able to see it then follow my reply above to see it
Rachitha
Visitor
This place is totally empty in my phone.. and the steps you have given there is no such a option called SHOW CALL LOG. Slightly_frowning_Face
Nabeel
Master
Rachitha
Visitor
Rachitha
Visitor
OMG bro .. thank you very much Slightly_smiling_Face Your answer is really effective. It worked Slightly_smiling_Face
