Please, help me, I can not boot my sola! I tried it so many times but it isn't boot it at all. Yesterday I update my software and it works, now I am trying to do something else but it don't boot.
Solved! Go to Solution.
did you unlocked the bootloader? flashed a custom rom? you have to elaborate
does the notification LED turn on when you connect it to a wall charger and/or computer? does the phone turn on but its on a bootloop?
Don't forget to mark the Correct Answers & Helpful Answers
The only thing that i have already do is to update my android
ok but you haven't answered my questions
The LED is working properly when it is connected to the charger or to the computer. I dont know that boot is the right word for that, i want to do that when i press the volume key down and then insert the usb cable to the phone. Thats is what i want to do
Is that mean that my bootloader is not unlocked?
when you turn off your phone > press and hold volume down > connect the USB cable does the LED turn green (flashmode)?
it goes in flashmode for a while and then goes to normal charging
try this
install SUS and update JAVA (google java download) > restart your PC > disable your firewall and antivirus > run SUS
try again
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
The same problem... First it goes to flashmode for 1-2 seconds then the LED turn to red then to green and start charging
if the battery its not at least at 50% its not going to work, also try a different USB port
