Battery Problem
James397
Battery Problem
Screenshot_2014-02-03-19-39-19.pngHello,
I have fully charge my phone but its work only 5 hours.
Screen takes 30 to 50 percent battery.
profile.country.RO.title
_alexdon_
Even my Xperia P adapter has a 1500 ma output.Your SP has a 2370 mah battery,so I would suggest somewhere around 1,5 A output.
alexdon
17 ANTWORTEN 17
_alexdon_
It is fine if the screen has 30-50% from the battery.Do you have any task killers or battery savers?Can you post a picture of the battery graph and draining apps?
alexdon
James397
No I am not using any type of app belongs to battery saver..
Can you please tell me how to upload screen shot.
_alexdon_
From the graph I can tell you that you are never charging it to 100%.Why are those fluctuations there?
alexdon
James397
Ya you arr right.. But its takes 4 to 5 hours to fully charge and after that its drain in next 5 hours... I do not have that much time to charge my phone twice a day
_alexdon_
What output does the adapter have?You might want to try another charger,with a larger output.
alexdon
James397
I am using charger which comes with celphone
_alexdon_
If you look at the adapter,what output voltage does it have?(mah)
alexdon
James397
Its 850mA
_alexdon_
You got nothing to do,it is a small voltage,that is why it takes so much.You could try other charger,but it is recommended to stick with sony default charger.
alexdon
