Xperia M5 Dual Issue
Muzy
 It's hard for me to say this is the best smartphone I have, but unfortunately there are many disadvantages. Nearly 2 years using it, the problem is battery problem, camera can not autofocus, rear camera vibrating when using it, overheating and shutdown (jumpstarted to bring back to life), bugs, can not trace exact location (miss about 5- 10 kilometers , High accuracy), 3 times send to Center, to many problem dissolve, and the last one can not run any game applications. I need some advice, do I need to find another smartphone or stay with Xperia M5? I hope the dev can consider this problem. Thanks
Ajith5
M5 is good phone. Software repair resolves all issues. But one thing you need to keep in mind that an ethernet cable coming to your home from outside is not good. You should have the fiber broadband or telephone wire and its "modem" installed in your home. This is the main reason many face problems. Also your computer OS need to be genuine.
My m5 has no heating and focussing issues at all.(used to have earlier, but after software repair, it is very good)
