M4 charging slowly
SOLVED
Prashast
Visitor
M4 charging slowly
Hello everyone,
I am prashast from India and i recently bought my new xperia device m4 e2363 from beginning it was charging very slow like 1% increases in 8-9minute.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
@Prashast
That's rather odd, you might want to get your phone inspected by your local Xperia Care
http://support.sonymobile.com/global-en/contactUs/
8 REPLIES 8
Samuel1
Hero
Well, the charging depends on a lot of factors. Do you charge via USB on the computer or via the wall socket? Are you using the phone while charging?
Uliwooly
@Prashast
Are you using the phone while charging? perhaps playing heavy games? or using a computer to charge your phone instead of a wall charger
Prashast
Visitor
No I don't use my phone while charging and I charge only through stock sony charger which was provided with my phone and when I connect my phone to pc through usb my pc doesn't recognize it. My charging speed is 7-9 minutes 1%.
Prashast
Visitor
I charge through wall socket and when I move my phone a little it stops charging.
Uliwooly
@Prashast
Prashast
Visitor
I have taken my phone they told that I need to submit my phone and they will repair and change parts if needed. Thanks @uliwooly.
Uliwooly
@Prashast
Anytime
kojiF
Visitor
that sounds like it is a problem with the usb cable try any other usb cable lying around
mine is also charging slow but I am using a dollarstore usb cable I suggest buy an sony usb cable it should make charging faster fix connection to pc
