M2 microphone
Erio
M2 microphone
Hi, I'm having problems with the microphone. when on the phone it seems to stop  working and people say its difficult to hear me- i end up shouting, any solutions?
42 ANTWORTEN 42
Thommo
Do you have Microphone noise suppression enabled - Settings / Call settings then scroll to the bottom
ewanbur
I have microphone noise suppression enabled and am also having the same issue
Thommo
Disable it - That's probably why you are both having issues
legnum7
if you disable it it gets worse. i'm having the same problem.
and i cant talk to people when on speakerphone becouse of the mic problem
also video and audio recordings are hard to hear and understand
I have the same problem on my m2 (d2303)
Mehhhh
Yeah I have the same issue, it's basically useless as a phone, can only use it for internet and stuff. Well, that was to be expected, i guess. It's shocking how there are no microphone settings apart from the one mentioned above. We should be able to control its volume at least, as we do with the speaker.
AshwinRuffian
I'm too having Microphone problem... I just checked with the ANDROID_MIC_TEST using *#*#7378423#*#* this code and test my microphones... secondary mic is good... but, primary mic is heard merely... i tested with both "Noise Reduction" enabled & disabled... Both are not heard.. Plz, help
Tags (4)
AshwinRuffian
I got it fixed...!! I just tear down the bottom sticker with the sticky layer... and, the microphone was working more fine...
Wolfman
I have got the same problem.  Can you explain how you actually fixed yours.  What bottom sticker are you referring to?  I need to use my M2 as a'phone for work and the muffled microphone is a real problem.  Thanks
AshwinRuffian
The bottom of the phone contains microphone & speaker holes... Which was covered by a NETTED&PATTERN-TYPE plastic layer & nylon layer... It's just a sticker... Tear down all the layers beneath that plastic layer... After that the holes of mic & loudspeaker are visible... Try this, it might work...
