can i install official 4.3 15.4.A.0.23 for c1905 in 1904?
Topic edited by Rickard
You should not try to install firmware for another model in your phone. Doing so may break the phone and void the warranty.
Android 4.3 is also being rolled out for C1904 but depending on your country/operator you may not have received it yet.
Sir,
i did that, all are good but my phone model is c1904. after i did it shows c1905. how can i resolve it? any problem for that?
To do that i assume you used a 3:rd party software like FlashTool or similar? To have the correct software installed you would need to install correct software using that software or contact a service location.
yes i tried pcc it shows phone is upto date... and it show my phone model is c1905... if through sus, reinstall may fix this problem?
sorry sir i did through flashtool.......
it void the warranty? only one thing it shows c1905........
Modifying the phones software may void the warranty of the phone. To install the correct software you would need to use that 3:rd party software again or contact an service location. It's not possible to change this using PC Companion or Update Service.
And I have updated my phone by updating the update center app from google and my model no is (C1904) so, is it legal?
yes.... because update is given sony........ and also there is no change in ur cusmtm number and model.........
